kitfox555(at)sbcglobal.ne Guest
dave
Posted: Mon Jan 29, 2007 7:24 am Post subject: stitching ribs |
Jerry,
that like saying is there a reason to stitch ?
How many problems has there actually been from fabirc lifting ?
Mine are not stitched.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Brett Walmsley
Posted: Mon Jan 29, 2007 8:15 am Post subject: Re: stitching ribs |
I stitched mine.
I'm glad I did.
It was fun and educational.
Took a day and a half to do both wings.
I would suggest not using the flat cord.
_________________ Brett
Model IV 1200/912UL |
dosmythe(at)cox.net Guest
Posted: Mon Jan 29, 2007 9:21 am Post subject: stitching ribs |
In my opinion, "Reasons Not To Stitch" is that many people consider stitching either too hard, too time consuming, or just plain too intimidating. None of these reasons are true once you get into the stitching process. "Reasons To Stitch"....At one time, Poly Fiber did not consider stitching an option but, considered it absolutely necessary. This was stated by Poly Fiber on several occasions back when I was stitching. My SS manual referred to stitching as an "OPTION". Poly Fiber greatly disagreed.
Don Smythe
dave
Posted: Mon Jan 29, 2007 9:49 am Post subject: stitching ribs |
Don, do you know of any failures of non sticked wings on Kitfox or Avids ?
The capstrip is about an inch wide plus the fillet that is formed when you attach.
I would guess unlessa poor job wasdone that you should fear the failure of the plywood itself before the glue lets go.
Dave
rjdaugh
Posted: Mon Jan 29, 2007 9:52 am Post subject: stitching ribs |
Ditto!
It took me a while to get the knot figured out working from the Polyfiber
book, but it was fun and I too am glad I did it.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
RRTRACK(at)aol.com Guest
Posted: Mon Jan 29, 2007 10:03 am Post subject: stitching ribs |
I built and flew an Avid Aerobat without the rib stitching and never had any problems in ten years even with the high G's. But when I built my STOL wings I rib stitched them and I would again because of the under camber wing design. Not hard to do and can only be done at time of covering.
Mark
Wisconsin
Avid STOL 582
Kitfox Vixen 912 UL
kitfoxmike
Posted: Mon Jan 29, 2007 10:26 am Post subject: Re: stitching ribs |
I rib stitched mine, and I guess it was mainly for piece of mine. I can't see the top of the wing and I do get a little radical in my flying, one less thing to think about. On the lacing I gave up on the multi knot and went with individual knots down the rib, went real fast once I did that.
n981ms(at)yahoo.com Guest
Posted: Mon Jan 29, 2007 10:53 am Post subject: stitching ribs |
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. [quote][b]
Posted: Mon Jan 29, 2007 11:16 am Post subject: stitching ribs |
I do not know of any wing failures due to not rib stitching. However, I do recall one rib cap failure (the one on the fuselage top outboard) that came loose in flight. Those 1" rib caps are held on by a small amount of glue and very small staples. The glue is holding in stress not shear. I do not recall seeing a fillet at the joint of the rib cap/rib. However, it's been a while. I would strongly suggest that the joint would break before the plywood.
Either way, we could talk all week about the joint/glue/break first/break second and it wouldn't matter. Poly Fiber highly recommends rib lacing on their product. Rib lacing provides a mechanical fastening between the top and bottom rib caps.
Don Smythe
dave
Posted: Mon Jan 29, 2007 11:38 am Post subject: stitching ribs |
Don ,
What did the former companies reco-mend ?
denney ,skystar, avid, and now Sportplanes ?
Show me where they separate and I will think about stitching. To me there really is little evidence that it is needed with the wide capstrip that we have.
I have covered Ultralights with fabirc that have 1/2 " or less width catstrip and never seen one come loose yet .
Dave
dave
Posted: Mon Jan 29, 2007 11:41 am Post subject: stitching ribs |
Don, I should have added that perhaps the faster Kitfoxes might be "more prone" to needing stitching that cruise over 130 mph but certainly not the majority of them have not proven that is is needed to be done. but Like I sais I certainly stand to be corrected.
Dave
Posted: Mon Jan 29, 2007 12:48 pm Post subject: stitching ribs |
Dave,
You made two post on the same subject so I put them back into one. see below.
First post,
"that cruise over 130 mph"
Not very many cruise over 130 MPH. Review the Poly Fiber web site http://www.polyfiber.com/. It does not mention any speed just said, "rib lace". They are the manufacture and should know the best procedures for installing their product.
Second post,
>>What did the former companies reco-mend ?>>
I already stated that my SS manual used the term "OPTIONAL" for rb lacing. Poly Fiber does not agree with the term "OPTIONAL". They want you to rib lace.
I have covered Ultralights with fabirc that have 1/2 " or less width catstrip and never seen one come loose yet .>>
I already stated there has been one cap failure. You said show me, I did. I don't need failure evidence. I just follow the Manufacture recommended procedure. In this case the Manufacture is Poly Fiber not Kitfox. Poly Fiber designed the fabric covering and how to install it. Denny/Skystar/etc. only use their product. I can't argue an exact airspeed where rib lacing or not will save your bacon. That is a foolish discussion.
Don Smythe
[quote] I do not know of any wing failures due to not rib stitching. However, I do recall one rib cap failure (the one on the fuselage top outboard) that came loose in flight. Those 1" rib caps are held on by a small amount of glue and very small staples. The glue is holding in stress not shear. I do not recall seeing a fillet at the joint of the rib cap/rib. However, it's been a while. I would strongly suggest that the joint would break before the plywood.
Don Smythe
dave
Posted: Mon Jan 29, 2007 12:57 pm Post subject: stitching ribs |
Don, Thanks fo the info. What does sportplane recomend?
I would tend to think that there is nothing wrong with or with-out stitching.
I have no trouble flying without stitching. And remeber Poly fibrre is most likely being over cautious for liability reasoning.
I don't think that if you not stitched that there is any case for alarm at all.
Dave
Posted: Mon Jan 29, 2007 2:19 pm Post subject: stitching ribs |
Dave,
Who is sportplane and what do they have to do with Poly Fiber procedures? As far as Poly Fiber being over cautious, that is the side I would follow for life critical aircraft components. If you don't want to rib lace, fine. There are more reasons to rib lace than not. It is the builders choice.
Don Smythe
Posted: Mon Jan 29, 2007 2:38 pm Post subject: stitching ribs |
Skystar said riblacing optional and riblaced the factory demonstrators that I saw. My polyfiber book specifically said it did not if the cap strips were 1 inch wide. There needed to be a mechanical fastener. It is not difficult or terribly time consuming.
I will never wish that I had not riblaced.
Somebody, some day might wish they had.
Maxwell in Georgia S6/TD/IO240
Don Smythe <dosmythe(at)cox.net> wrote:
[quote] Dave,
First post,
Second post,
Don Smythe
Don Smythe
dave
Posted: Mon Jan 29, 2007 4:23 pm Post subject: stitching ribs |
Sportplane -- I mean John McBean
Poly fiber is asbsolutly being careful for liability reasons. no doubt about that.
Personally it is a choice, but then again so is a BRS chute ......in a Kitfox I don;t see the need for either.
I won't fly in a plane that needs a parachute unless it strapped to myself when a test pilot.
Dave
Posted: Mon Jan 29, 2007 5:03 pm Post subject: stitching ribs |
Dave,
No offence to John but, the plain fact is that Poly Fiber (the Manufacturer) is recommending rib stitching on "their" product. Why is that so hard to accept? You say that Poly Fiber is "absolutely" being liability careful and there is "NO" doubt about that. Do you have first hand knowledge of the internal workings of Poly Fiber? How can you make such a statement?
Don Smythe
dave
Posted: Mon Jan 29, 2007 6:48 pm Post subject: stitching ribs |
Don,
What does the airplane Kit manufacturer ask for in build manual?
That is what is required for inspection here. Possibly more but you cannot make a design change without approval.
Don, you summed it up here quite well in your quote " I do not know of any wing failures due to not rib stitching. "
anymore questions ?
Dave
eskflyer(at)lvcisp.com Guest
Posted: Mon Jan 29, 2007 7:38 pm Post subject: stitching ribs |
Jerry
My plane is a Kitfox 2 high lift wing and is not rib stitched. Never had a problem in over 700 hours now, she started her flying career in 99. I did not build the plane. If i were to do it ,I would ribstitch . I love the look of a nicely done stitch job.
John Perry
