Deems Davis
Posted: Sat Feb 03, 2007 10:28 am Post subject: Prop/Engine "Sag"Question |
For those who have finished your plane or previous planes. I'm
interested in your real life experience regarding whether you've
experienced or noticed any sag in your engine since initially mounting
it. I've heard that after a hundred or two hundred hours that the engine
will settle on the mounts which results in the prop dropping ( 1/8",
3/16", 1/4" , ?????). Is this a real phenomena or an urban airport myth?
If its real, how much 'sag' have you experienced? I'm leery of adding a
'fudge factor' not knowing exactly what it should be, and 1/8" tolerance
isn't what I'd like to achieve. Am I striving for the holy grail? It
seems like there ought to be a better way to ensure things fit after
flying for a while I'm in the process of installing my cowl and would
like to have it and the spinner mate evenly when it's all said and done.
Thanks for any information received
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Posted: Sat Feb 03, 2007 10:45 am Post subject: Prop/Engine "Sag"Question |
Deems Davis wrote:
engine will settle on the mounts which results in the prop dropping (
1/8", 3/16", 1/4" , ?????). Is this a real phenomena or an urban
airport myth?
Yup, it's real.
| Quote: | If its real, how much 'sag' have you experienced? I'm leery of adding
a 'fudge factor' not knowing exactly what it should be, and 1/8"
tolerance isn't what I'd like to achieve. Am I striving for the holy
grail? It seems like there ought to be a better way to ensure things
fit after flying for a while I'm in the process of installing my cowl
and would like to have it and the spinner mate evenly when it's all
said and done.
Lot's of variables in how much sag ...... the specific mount (the rubber
hardness can change drastically between 'models') makes a difference as
well as engine/prop weight and heat ....... but the sag can be taken
care of by adding washers under the mounts.
Linn ......aerobatic mounts don't sag a whole lot!!!
Deems Davis # 406
Posted: Sat Feb 03, 2007 10:53 am Post subject: Prop/Engine "Sag"Question |
I have looked at this. If there is any sag in N256H, it is 1/8" or less.
It is not enough to be very noticeable after 300 hours. YMMV, but this is
what I have seen. I would recommend rigging it up about 1/8" or 1/16" to
allow for it, but even at this you have to look closely to notice this
difference.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Tim Olson
Posted: Sat Feb 03, 2007 11:18 am Post subject: Prop/Engine "Sag"Question |
One thing to keep in mind is that none of the planes flying are all
that old, when compared with how many years those engine mounts
will be installed. It's certainly not an *average* number of
hours that people like some of us are putting on, so when someone
says "in a couple hundred hours", for many homebuilts that's going
to mean 5 years.
2 things to consider:
A) You can always just not mount it as high to compensate, but just
plan on replacing your rubber mounts every 3 or 4 years.
B) I would definitely leave at least the recommended gap between the
cowl face and the prop hub/spinner. That's one area I wouldn't want
to see rub.
difference.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
carl.froehlich(at)cox.net Guest
Posted: Sat Feb 03, 2007 1:11 pm Post subject: Prop/Engine "Sag"Question |
I assumed 3/16" sag on my RV-8A. After 300 hours, no sag.
Carl Froehlich
zackrv8
Posted: Sat Feb 03, 2007 1:42 pm Post subject: Re: Prop/Engine |
Deems,
I mounted my spinner bulkhead flush with the top of the cowl on my RV8. I have the regular motor mount rubber (non aerobatic). After 1000 hours and many aerobatic flights up to 4 G's, I have no sag.
Of course, my 4 cylinder doesn't weigh as much as the 6 cylinder engines. I plan on mounting my RV10 spinner flush.
Zack
| Deems Davis wrote: | For those who have finished your plane or previous planes. I'm
Deems Davis # 406
http://deemsrv10.com/ |
_________________ RV8 #80125
RV10 # 40512 |
tadsargent(at)bellsouth.n Guest
Posted: Sat Feb 03, 2007 3:13 pm Post subject: Prop/Engine "Sag"Question |
Deems, my 7A has had a 360 on the nose for 2 years and 200 hours flying
time. I have negligible sag. Make it look good now. You will never notice
it again when you get flying.
Tad Sargent
Deems Davis
Posted: Sat Feb 03, 2007 4:17 pm Post subject: Prop/Engine "Sag"Question |
Wow, This list is great! I also posted the same question on VAF. While
there's some difference of opinion, the majority of the real life
responses indicated little or no noticeable sag after several hunderd
(1600) hours and many years. The other piece of useful information was
that if some sag does occur and you want to take it out. a couple of
properly sized washers at the annual condition inspection would take
care of the problem. So. I've decided to make it fit flush now, and
adjust if and when it gets noticable and annoying.
THANKS again for all who have replied.
Deems Davis # 406
Now if getting the seam tight and straight between the cowl and fuse was
just as easy..................................
kdbelue(at)charter.net Guest
Posted: Sat Feb 03, 2007 4:39 pm Post subject: Prop/Engine "Sag"Question |
After 5 years and over 700 hrs, my spinner has sagged about 3/16". I had
always thought I would put some washers in to raise it, but when I tried to
there were interference problems with the airscoop. Every plane is
different - I just left mine the way it is because there wasn't enough room
to modify the front of my airbox. If you start out with the spinner flush
with the cowl it will still look good even if it sags 1/8".
Kevin Belue
RV-6A flying
RV10 finish
bpattonsoa(at)yahoo.com Guest
Posted: Sat Feb 03, 2007 5:47 pm Post subject: Prop/Engine "Sag"Question |
450 hours in an RV-6A. It was a myth until around 250-300 hours. It has now sagged about 3/16 to 1/4.
Seems to have stopped, but who can tell. Next big annual I plan on putting washers on the bottom mounts.
Bruce Patton
dasduck(at)comcast.net Guest
Posted: Sun Feb 04, 2007 9:02 am Post subject: Prop/Engine "Sag"Question |
Deems,
I allowed for sag in my O-360 wood prop RV-6 which it did, about 3/16”.
After 500hrs I changed to a Hartzell heavy prop and it sagged some more, so I re-aligned with the washers between the engine flanges and the ‘pucks’.
There are various thicknesses of those washers and it is an easy, effective way to improve the alignment of the spinner to the cowl.
Allow for a small amount of sag, and if it sags a bit more than you allowed for, shim it.
Don
RV-6 980hrs
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Patton
Sent: Saturday, February 03, 2007 5:47 PM
Subject: Re: RV10-List: Prop/Engine "Sag"Question
Bruce
-- Release Date: 2/3/2007
2/3/2007
billderou(at)yahoo.com Guest
Posted: Sun Feb 04, 2007 10:15 am Post subject: Prop/Engine "Sag"Question |
Another approach which may slow the aging process is to use stiffer pucks on the upper forward and the lower aft mounts such as Piper recommends for the 260 Commanche. For the Commanche, Lord recommends a mix of -34 and -35 pucks which I installed and are rare. No sag yet but I only have 70 hours on my RV-10.
Perhaps Van should be asked to get another opinion. I know he has offered stiffer pucks for aerobatic applications in the past.
Bill DeRouchey
billderou(at)yahoo.com (billderou(at)yahoo.com)
N939SB, flying
don wentz <dasduck(at)comcast.net> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Deems,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Don
RV-6 980hrs
Subject: Re: Prop/Engine "Sag"Question
Bruce
Ray.R.Doerr(at)sprint.com Guest
Posted: Mon Feb 05, 2007 11:11 am Post subject: Prop/Engine "Sag"Question |
I've heard the 4 bagger guys say 1/4" so I added to that since the 6 cylinder sits out there even further. I setup my Cowl for 3/16" and now with 210 hours on it, it has settled about 1/4", so I would say use 1/4" as your starting point, not 3/16" and you should be good. I am now going to shim behind my mounts with a steel washer to get it bang on.
Thank You
Ray Doerr
40250
N519RV
