		Deems Davis
				 Posted: Sat Feb 03, 2007 10:28 am    Post subject: Prop/Engine "Sag"Question |
				For those who have finished your plane or previous planes. I'm
 interested in your real life experience regarding whether you've
 experienced or noticed any sag in your engine since initially mounting
 it. I've heard that after a hundred or two hundred hours that the engine
 will settle on the mounts which results in the prop dropping ( 1/8",
 3/16", 1/4" , ?????). Is this a real phenomena or an urban airport myth?
 If its real, how much 'sag' have you experienced? I'm leery of adding a
 'fudge factor' not knowing exactly what it should be, and 1/8" tolerance
 isn't what I'd like to achieve. Am I striving for the holy grail?  It
 seems like there ought to be a better way to ensure things fit after
 flying for a while I'm in the process of installing my cowl and would
 like to have it and the spinner mate evenly when it's all said and done.
 Thanks for any information received
 Deems Davis # 406
 Finishing - ( A Misnomer ! )
 http://deemsrv10.com/
				 Posted: Sat Feb 03, 2007 10:45 am    Post subject: Prop/Engine "Sag"Question |
				Deems Davis wrote:
  engine will settle on the mounts which results in the prop dropping (
  1/8", 3/16", 1/4" , ?????). Is this a real phenomena or an urban
  airport myth?
 Yup, it's real.
  	  | Quote: | 	 		   If its real, how much 'sag' have you experienced? I'm leery of adding
  a 'fudge factor' not knowing exactly what it should be, and 1/8"
  tolerance isn't what I'd like to achieve. Am I striving for the holy
  grail?  It seems like there ought to be a better way to ensure things
  fit after flying for a while I'm in the process of installing my cowl
  and would like to have it and the spinner mate evenly when it's all
  said and done.
 Lot's of variables in how much sag ...... the specific mount (the rubber
 hardness can change drastically between 'models') makes a difference as
 well as engine/prop weight and heat ....... but the sag can be taken
 care of by adding washers under the mounts.
 Linn ......aerobatic mounts don't sag a whole lot!!!
  Deems Davis # 406
				 Posted: Sat Feb 03, 2007 10:53 am    Post subject: Prop/Engine "Sag"Question |
				I have looked at this.  If there is any sag in N256H, it is 1/8" or less.
 It is not enough to be very noticeable after 300 hours.  YMMV, but this is
 what I have seen.  I would recommend rigging it up about 1/8" or 1/16" to
 allow for it, but even at this you have to look closely to notice this
 difference.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
		Tim Olson
				 Posted: Sat Feb 03, 2007 11:18 am    Post subject: Prop/Engine "Sag"Question |
				One thing to keep in mind is that none of the planes flying are all
 that old, when compared with how many years those engine mounts
 will be installed.  It's certainly not an *average* number of
 hours that people like some of us are putting on, so when someone
 says "in a couple hundred hours", for many homebuilts that's going
 to mean 5 years.
 2 things to consider:
 A) You can always just not mount it as high to compensate, but just
 plan on replacing your rubber mounts every 3 or 4 years.
 B) I would definitely leave at least the recommended gap between the
 cowl face and the prop hub/spinner.  That's one area I wouldn't want
 to see rub.
  difference.
  Jesse Saint
  Cell: 352-427-0285
  Fax: 815-377-3694
		carl.froehlich(at)cox.net Guest
				 Posted: Sat Feb 03, 2007 1:11 pm    Post subject: Prop/Engine "Sag"Question |
				I assumed 3/16" sag on my RV-8A.  After 300 hours, no sag.
 Carl Froehlich
		zackrv8
				 Posted: Sat Feb 03, 2007 1:42 pm    Post subject: Re: Prop/Engine |
				Deems,
   I mounted my spinner bulkhead flush with the top of the cowl on my RV8.  I have the regular motor mount rubber (non aerobatic).  After 1000 hours and many aerobatic flights up to 4 G's, I have no sag.
   Of course, my 4 cylinder doesn't weigh as much as the 6 cylinder engines.  I plan on mounting my RV10 spinner flush.
 Zack
  	  | Deems Davis wrote: | 	 		  For those who have finished your plane or previous planes. I'm
 Deems Davis # 406
 http://deemsrv10.com/ |
  _________________ RV8 #80125
RV10 # 40512 |
		tadsargent(at)bellsouth.n Guest
				 Posted: Sat Feb 03, 2007 3:13 pm    Post subject: Prop/Engine "Sag"Question |
				Deems, my 7A has had a 360 on the nose for 2 years and 200 hours flying
 time.  I have negligible sag.  Make it look good now.  You will never notice
 it again when you get flying.
 Tad Sargent
		Deems Davis
				 Posted: Sat Feb 03, 2007 4:17 pm    Post subject: Prop/Engine "Sag"Question |
				Wow, This list is great! I also posted the same question on VAF. While
 there's some difference of opinion, the majority of the real life
 responses indicated little or no noticeable sag after several hunderd
 (1600) hours and many years. The other piece of useful information was
 that if some sag does occur and you want to take it out. a couple of
 properly sized washers at the annual condition inspection would take
 care of the problem. So. I've decided to make it fit flush now, and
 adjust if and when it gets noticable and annoying.
 THANKS again for all who have replied.
 Deems Davis # 406
 Now if getting the seam tight and straight between the cowl and fuse was
 just as easy..................................
		kdbelue(at)charter.net Guest
				 Posted: Sat Feb 03, 2007 4:39 pm    Post subject: Prop/Engine "Sag"Question |
				After 5 years and over 700 hrs, my spinner has sagged about 3/16". I had
 always thought I would put some washers in to raise it, but when I tried to
 there were interference problems with the airscoop. Every plane is
 different - I just left mine the way it is because there wasn't enough room
 to modify the front of my airbox. If you start out with the spinner flush
 with the cowl it will still look good even if it sags 1/8".
 Kevin Belue
 RV-6A flying
 RV10 finish
		bpattonsoa(at)yahoo.com Guest
				 Posted: Sat Feb 03, 2007 5:47 pm    Post subject: Prop/Engine "Sag"Question |
				450 hours in an RV-6A.  It was a myth until around 250-300 hours.  It has now sagged about 3/16 to 1/4.
  Seems to have stopped, but who can tell.  Next big annual I plan on putting washers on the bottom mounts.
  Bruce Patton
		dasduck(at)comcast.net Guest
				 Posted: Sun Feb 04, 2007 9:02 am    Post subject: Prop/Engine "Sag"Question |
				Deems,
 I allowed for sag in my O-360 wood prop RV-6 which it did, about 3/16”.
 After 500hrs I changed to a Hartzell heavy prop and it sagged some more, so I re-aligned with the washers between the engine flanges and the ‘pucks’.
 There are various thicknesses of those washers and it is an easy, effective way to improve the alignment of the spinner to the cowl.
 Allow for a small amount of sag, and if it sags a bit more than you allowed for, shim it.
 Don
  RV-6  980hrs
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Patton
  Sent: Saturday, February 03, 2007 5:47 PM
  Subject: Re: RV10-List: Prop/Engine "Sag"Question
 Bruce
      --  Release Date: 2/3/2007
  2/3/2007
		billderou(at)yahoo.com Guest
				 Posted: Sun Feb 04, 2007 10:15 am    Post subject: Prop/Engine "Sag"Question |
				Another approach which may slow the aging process is to use stiffer pucks on the upper forward and the lower aft mounts such as Piper recommends for the 260 Commanche. For the Commanche, Lord recommends a mix of -34 and -35 pucks which I installed and are rare. No sag yet but I only have 70 hours on my RV-10.
   Perhaps Van should be asked to get another opinion. I know he has offered stiffer pucks for aerobatic applications in the past.
   Bill DeRouchey
   billderou(at)yahoo.com (billderou(at)yahoo.com)
   N939SB, flying
 don wentz <dasduck(at)comcast.net> wrote:
   [quote]      v\:* {behavior:url(#default#VML);}  o\:* {behavior:url(#default#VML);}  w\:*  {behavior:url(#default#VML);}  .shape {behavior:url(#default#VML);}                Deems,<?xml:namespace prefix  = o ns = "urn:schemas-microsoft-com:office:office" />
   Don
 RV-6  980hrs
 Subject: Re: Prop/Engine "Sag"Question
     Bruce
		Ray.R.Doerr(at)sprint.com Guest
				 Posted: Mon Feb 05, 2007 11:11 am    Post subject: Prop/Engine "Sag"Question |
				I've heard the 4 bagger guys say 1/4" so I added to that since the 6 cylinder sits out there even further.  I setup my Cowl for 3/16" and now with 210 hours on it, it has settled about 1/4", so I would say use 1/4" as your starting point, not 3/16" and you should be good.  I am now going to shim behind my mounts with a steel washer to get it bang on.
 Thank You
 Ray Doerr
 40250
 N519RV
