Most economical cruse speed
DAquaNut(at)aol.com
PostPosted: Sun Feb 04, 2007 8:19 pm    Post subject: Most economical cruse speed Reply with quote
Fire- Flyers,
Has anyone done any research or testing or even guessing as to what RPMs give the most economy and most range with a 66" Ivo and a 447 on the Firefly? Best I can tell my range is no more than about 50 to 54 miles on 4.5 gallons. Any one do any better than that on a 5 gallon tank? I could find nothing on the subject in the Archives .
Ed ( in Houston where it is starting to Dry out a little)
herbgh
PostPosted: Mon Feb 05, 2007 7:54 am    Post subject: Most economical cruse speed Reply with quote
Ed
I fly with a two blade 62 inch ivo with minimum pitch..Have a points 447--came brand new with the second hand kit.. Never could get the engine to swing a three blade 66 inch ivo... no matter the pitch.. Std jets...
Flies very satisfactorily on the 62 incher... here are some log book entries... have hobbs..meter.. 62 miles 1.5 hours... 4 take offs and landings..Smile 3.05 gals and 62 miles... 7-3-2006 another.... Home to Glasgow to Hodgenville to Glasgow to home... 132.4 miles 6.25 gals. Flew with another Firefly and likely spent most of our time at 5200 rpms? I like to run abt 5800 rpms.. 8-19-2006.. nuther.... home to Glasgow to Rough River state park(ky state EAA flyin) to Glasgow to home... 3.20 hours---8.9 gals 173 miles.. spent abt 10 miles dodging storm.... 9-9-2006... lastly home to No Bob to Wildwood to Welcome to home... 2 hours... 5.5 gals 106 miles... 10-7-2006..
Looks as if I burn in the nieghborhood of 2.2 to 2.75 gals an hour.. average abt 20 mpg.. Herb
On Sun, 4 Feb 2007 23:18:15 EST DAquaNut(at)aol.com (DAquaNut(at)aol.com) writes:
[quote] Fire- Flyers,
matronics.com
jimhefner
PostPosted: Mon Feb 05, 2007 10:03 am    Post subject: Re: Most economical cruse speed Reply with quote
Ed, my old Firefly had a 66" IVO with pitch set for 6200 static. I usually cruised at 5100 - 5300 rpms and based on GPS trip summaries and fuel used, I tended to see 20 mpg avg, which was just under 3 gal/hr cruising 55-60. Hope that helps.
Jim Hefner
Tucson, AZ
Thom Riddle
PostPosted: Mon Feb 05, 2007 1:34 pm    Post subject: Most economical cruse speed Reply with quote
DAuquaNut,
I cannot tell you about FireFlys per se but can tell you that for the
lowest fuel consumption per mile flown in calm winds generally occurs
fairly close to Vy, best rate of climb speed in most airplanes. The
least fuel consumption per hour of flight generally occurs at a lower
speed closer to Vx, best angle of climb speed. If you know those
speeds you will be pretty close to what you are looking for if airspeed
is what you want.
If engine speed is what you want, the older Rotax manuals used to have
a specific fuel consumption chart for all their engines which indicated
at what engine speed you could expect to make the most
horsepower/gallon of fuel used. I've not seen one of these charts in a
very long time. Since they now show HP charts and fuel consumption
charts (at full load) you could do some math by dividing the GPH by HP
to come up with your own version of this specific fuel consumption
data. But it would not do you much good since that would be valid at
full load only and would not tell you much about partial load cruising.
The V speeds will give you closer guestimate for that purpose.
If you have a fuel flow gage, then you could do your own tests.
Thom in Buffalo
Freezing my "do not archive" off
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
planecrazzzy
PostPosted: Mon Feb 05, 2007 3:13 pm    Post subject: Re: Most economical cruse speed Reply with quote
I have a Fuel Flow meter / Fuel gauge , I switch over to see the fuel flow alot....I'm suprised how high it can get....When I'm cruising I check to see if I'm pushing it too much....Backing off the throttle "just a little" can really save the fuel.... I don't know how you could tell otherwise....
Conditions change too much....
I like that Fuel Flow meter !
Gotta Fly...
Mike in MN
jim
PostPosted: Mon Feb 05, 2007 5:32 pm    Post subject: Most economical cruse speed Reply with quote
So Mike, what are the numbers?
Jim
N. Idaho
Steve Boetto
PostPosted: Tue Feb 06, 2007 5:30 am    Post subject: Most economical cruse speed Reply with quote
Has anyone considered that as you reduce the rpms on a 447 below 5800 that you are dropping off the tuned rpm for the exhaust pipe and you may be increasing wear and adding carbon to the rings?
steve
PostPosted: Tue Feb 06, 2007 5:57 am    Post subject: Most economical cruse speed Reply with quote
5800 that
be
| steve
Morning Steve:
I have, but the majority of the Kolb List wants to make JD tractors
out of them. Something about wearing them out sooner if you turn more
rpm, even though the engine was designed to cruise at 5,800 rpm and
above. It is a continuous duty engine that does much better at or
above 5,800 rpm. Without going back to look it up, the engine is
capable of 6,500 rpm max continuous.
Lots of folks feel the same way about the 912 series engines that are
5,500 rpm max continuous. In my case, if I don't turn at least 5,000
rpm, I can not keep the engine oil and CHT up to minimum temps.
Wonder if we could put my 1936 JD D engine on a Firestar. It gets its
max hp at 900 rpm.
25F and sunny
ul15rhb(at)juno.com
PostPosted: Tue Feb 06, 2007 6:23 am    Post subject: Most economical cruse speed Reply with quote
John and others, I am flying my Firestar with a 5100 RPM cruise every
time I fly. I have over 450 hours on the 447. I'm a believer that
less RPM's equates to less wear. So far, so good.
Ralph Burlingame
Original Firestar/447
20 years flying it
5800 that
be
| steve
Morning Steve:
more
its
max hp at 900 rpm.
25F and sunny
________________________________________________________________________
Interested in getting caught up on today's news?
Click here to checkout USA TODAY Headlines.
http://track.juno.com/s/lc?s=198954&u=http://www.usatoday.com/news/front.htm?csp 4
planecrazzzy
PostPosted: Tue Feb 06, 2007 3:00 pm    Post subject: Re: Most economical cruse speed Reply with quote
Hi Jim,
Just like a Detroit Diesel, I keep'r scream'n
Mostly around 5900 - 6000
I don't really get good GPH .... But sometimes when I see the Fuel flow
at 6 plus GPH , I back it down....Some of that is during climb
But even at cruise I see 5 gph sometimes
If I try for 3.5 gph like they say it's suppose to get , My RPM's would be way too low....
With a slight headwind I can almost go 100 miles on 8 gals , That's a 2 gal reserve ( doesn't mean 1 gal in each tank - uneven )
Gotta Fly...
Mike & "Jaz" in MN
icrashrc
PostPosted: Wed Feb 07, 2007 2:18 am    Post subject: Re: Most economical cruse speed Reply with quote
its
max hp at 900 rpm.
If you're aiming for economy you should run the JD closer to max torque. I would aim for about 500rpm on the 'D'. Might wanna add a few pounds of air to the Firestars tires as well! Smile
Scott
www.ill-EagleAviation.com
jimhefner
PostPosted: Wed Feb 07, 2007 8:54 am    Post subject: Re: Most economical cruse speed Reply with quote
steve
Steve, I don't know about your 447 or your setup but I know based on a couple hundred hours of experience that this was not a problem. As power was reduced on approach I had to avoid the 4200-4400rpm range, where the exhaust tuning is a problem, causing EGT's to go up sharply, but other than that, there was no problem. The 447 has plenty of power so even though at lower rpm settings it is not up on the high end of the power curve , there is plenty of power for a comfortable cruise speed. The engine was not laboring a bit... more like purring like a kitten. I used 100:1 synthetic so there was no carbon build-up and looking at the rings through the exhaust port, they were clean and free.... not a slap mark on either piston after more than 200 hrs.... looked new inside! A friend once looked into my exhaust ports and couldn't believe how clean and new it looked. My EGT's were 1050 and CHT was 225.... I don't think there was much wear going on there.
I know there are always debates on this topic and everyone has a right to their own views and you all can run your engines at 5800 or above at cruise all you want, just sharing my experience with the list for those that might want to try something similar. I always burned a little under 3 gal/hr using that approach and setup.... a 447 shouldn't be burning much more than 3 gph or something is not right with the setup in my opinion.
Steve, what are your numbers? (GPH, EGT/CHT, cruise speed, static rpm)
Jim Hefner
Tucson, AZ
ul15rhb(at)juno.com
PostPosted: Wed Feb 07, 2007 9:17 am    Post subject: Most economical cruse speed Reply with quote
I'm in 100% agreement with Jim on this topic. 5000-5100 RPM is where
the best economy is for the 447 on the Firestar or Firefly at about
2.5 to 2.7 gallons per hour.
Ralph Burlingame
Original Firestar w/447
20 years flying it
steve
rpm)
Jim Hefner
Kolbless in Tucson Sad
http://forums.matronics.com/viewtopic.php?p=93447#93447
Richard Pike
PostPosted: Wed Feb 07, 2007 11:25 am    Post subject: Most economical cruse speed Reply with quote
The Rotax 532 had a noticable "on the pipe/off the pipe" range that fell in the lower 5000 rpm range, and years ago I used to fly a Quicksilver MX with a 377 that had a very noticable range where it was either on or off the pipe. It is easy to tell engines affected in this manner because they will not hold a constant rpm, but will gain or lose rpm within certain rpm ranges. The 90 series 582 I am using does not do that that I have ever noticed, and I understand that the blue head is even better about it. So being on/falling off the pipe is not a factor.
Last annual, rings were clean & free, top of piston was very lightly carboned, underside of head had a couple carbon patches about as big as a fingernail, a couple small streaks of carbon buildup in the exhaust manifold. Left it all alone, put it back together.
Using Phillups Injex, normally cruise around 5100-5300 solo, 5500-5600 with a passenger. Quiet and comfortable at around 63 mph.
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
tkrolfe(at)usadatanet.net
PostPosted: Wed Feb 07, 2007 11:29 am    Post subject: Most economical cruse speed Reply with quote
Ralph Burlingame
20 years flying it
steve
rpm)
Jim Hefner
Jim, Steve,
I guess that was what I was trying to get across earlier in my reply to
Ed with his FireFly. Seems nobody want's to believe 2 or 2.25 gal/hr.
on a 447. Flying at 5,000 to 5,200 rpm in front of a Tennessee wood
prop for 620 hr's.
Terry - Firefly #95
jimhefner
PostPosted: Wed Feb 07, 2007 9:59 pm    Post subject: Re: Most economical cruse speed Reply with quote
Terry, if you are only burning 2- 2.25 gph, you are doing better than I ever did. I averaged around 2.75 with the 66" IVO on the FF. Sounds like you have a good thing going, so don't change anything. How long is your Tennessee prop?
Jim Hefner
Tucson, AZ
Thom Riddle
PostPosted: Thu Feb 08, 2007 5:06 am    Post subject: Most economical cruse speed Reply with quote
When I was flying an early Firestar with 377 engine, I typically
cruised at about 5200 rpm when I was enjoying the scenery, which
yielded about 45-50 mph, which is the speed I flew at much of the time.
When trying to set somewhere, I'd push it up to 5600-5800 rpm for a
55-60 mph cruise. I kept complete records on total fuel consumption for
the time I had this airplane and the average fuel consumption over that
time was 2.8 gph and had no engine problems whatsoever during that
time.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Thu Feb 08, 2007 6:37 am    Post subject: Most economical cruse speed Reply with quote
Morning Gang:
I have discovered there are two modes of flight to determine fuel
consumption.
1-Flying around the patch.
2-Cross country.
Flying around the patch burns about 50 to 75% of the fuel that you
burn cross country.
If you want a true fuel burn, it is best, in my opinion, to fly some
cross country. Most important info is time of flight and maintaining
"your" cruise rpm, except for take off and landings. Probably should
fly, at least, one hour legs to verify fuel burn. Fuel tank should be
topped off prior to the flight and topped off again when you complete
your flight. You will be surprised how much fuel you burn, if you
have never done a fuel check before.
Remember, flying and playing around the patch will give you much
better fuel consumption than flying a true cross country flight.
PostPosted: Thu Feb 08, 2007 6:58 am    Post subject: Most economical cruse speed Reply with quote
jimhefner wrote:
--> Kolb-List message posted by: "jimhefner" <hefner_jim(at)msn.com>
Jim Hefner
Jim,
My prop is 66" also. Even at 2.75 gph, you were doing better than most. Rpm has a lot to do with gph on a draggy aircraft like the FireFly. My fuel consumption goes up dramatically when I push the rpm and airspeed to get someplace. If I were to put a full enclosure on it and streamline struts I think it wouldn't be as big a factor. Jack Hart is the master at that!
Terry _ FireFly #95
Time to get back into a Kolb!!!!!! Smile
