24v aux power port?
donjohnston
PostPosted: Thu Mar 06, 2014 7:07 pm    Post subject: 24v aux power port? Reply with quote
I've been looking for an auxiliary power port (courtesy port). All the ones I see are advertised for use in 12v electrical systems. But I'm 24v.
For example:
http://www.amazon.com/Accessory-Outlet-Lighter-Marine-Motorcycle/dp/B005GSFK6U
But these are passive devices, right? As long as I keep the current within the correct values, shouldn't it work with no problems?
-Don
rickofudall
PostPosted: Thu Mar 06, 2014 8:01 pm    Post subject: 24v aux power port? Reply with quote
It's just a couple of contacts. As long as you keep the amps from melting them, why would voltage matter?
Rick Girard
On Thu, Mar 6, 2014 at 9:07 PM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
For example:
-Don
http://forums.matronics.com/viewtopic.php?p=419895#419895
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
ceengland7(at)gmail.com
PostPosted: Thu Mar 06, 2014 8:27 pm    Post subject: 24v aux power port? Reply with quote
Risk of a passenger trying to power a 12 V device on the 24 V supply?
[quote] On Mar 6, 2014, at 10:00 PM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Rick Girard
> On Thu, Mar 6, 2014 at 9:07 PM, donjohnston <don(at)velocity-xl.com> wrote:
> For example:
> -Don
> le, List Admin.
> ="_blank">http://www.matronics.com/contribution
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
loboflyer(at)gmail.com
PostPosted: Thu Mar 06, 2014 8:34 pm    Post subject: 24v aux power port? Reply with quote
Using a lighter socket on a 24V system is possible, but invites disaster.  I did a quick survey around the house and while most of the lighter socket plugs I found work with 24Vdc, it would be my luck that I'd find one that didn't, the hard way (for example, my ham radio HT which takes 16.8V max).  Have you considered using a 24-12V DC-DC converter wired up behind the socket, or do you need 24V for accessories?
  -Jeff-
On Thu, Mar 6, 2014 at 8:07 PM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
[quote]--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
For example:
-Don
le, List Admin.
donjohnston
PostPosted: Fri Mar 07, 2014 4:21 am    Post subject: Re: 24v aux power port? Reply with quote
The Cessna I've had for 15 years has a 24v power jack and I've never had a problem with passengers connecting anything to it. Partly because I don't let my passengers connect things to my airplane without asking first (and if they didn't ask, they deserve what they get). Very Happy And secondly, it's already in use.
So can someone second that there is no difference in the construction of one of these 12v connectors?
PostPosted: Fri Mar 07, 2014 4:22 am    Post subject: Re: 24v aux power port? Reply with quote
How about installing two DC power outlets, one for 24 volts and one for 12 volts? One like this can be used for 24 volts without the danger of a 12 volt device being plugged into it. http://www.mouser.com/ProductDetail/Switchcraft/712A/?qs=sGAEpiMZZMv1TUPJeFpwbvDLoO7VplWmGzPCelncVas%3d
A DC to DC converter can supply 12 volts to the other cigarette lighter type outlet. http://www.ebay.com/itm/24V-Step-Down-to-12V-DC-DC-Converter-Regulator-20A-240W-Converter-USA-Shipping-/121289155547?pt=LH_DefaultDomain_0&hash=item1c3d65a3db
Joe
Joe Gores
rickofudall
PostPosted: Fri Mar 07, 2014 6:30 am    Post subject: 24v aux power port? Reply with quote
Label it clearly, make sure it's isolated from any other circuit, and control what your passengers bring into the aircraft.
Rick
On Thu, Mar 6, 2014 at 10:26 PM, Charlie E <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
On Mar 6, 2014, at 10:00 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
For example:
-Don
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
donjohnston
PostPosted: Fri Mar 07, 2014 8:46 am    Post subject: Re: 24v aux power port? Reply with quote
Kind of hard to plug my Garmin 396 into that.
PostPosted: Fri Mar 07, 2014 4:39 pm    Post subject: 24v aux power port? Reply with quote
To answer your original question, the lighter jack you mentioned should work with 24V.  Typically voltage ratings are either (1) for safety reasons, where it is easy to stick a finger in and get a shock, or (2) for dielectric withstanding/arcing.  12 to 24V isn't enough to trigger either restriction.  While alternatives have been suggested, fuse it properly and you'll be fine.
  -Jeff-
On Fri, Mar 7, 2014 at 9:46 AM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
http://forums.matronics.com/viewtopic.php?p=419922#419922
le, List Admin.
donjohnston
PostPosted: Fri Mar 07, 2014 4:46 pm    Post subject: Re: 24v aux power port? Reply with quote
Thank you! Smile
