		Alan Carter
  Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
				 Posted: Sun Oct 26, 2014 12:15 pm    Post subject: 57 minuts on 13 ltrs on a 914 |
				Hello All.
 I have fitted an MGI fuel flow meter with 2 sender on my 914,
 The senders came with labels showing the k factor for a flow of 16 gallons an hour, did the conversion to ltrs per hour set them up but did not  give the correct fuel burn ended up say calling for 12 lts  and overflowing when 11 where put in.
 I have them set Flow K 9100 and (Return K 9167 this was the original calculated figure ) so have only adjusted the flow sender.
 The gauge called for 13 ltrs and I put 13 ltrs in and it was level with the filler cap.
 In the cruise it was saying 15 to 16 an hour.
 My Ipad comes in timing at speeds between 5 to 10 kts so take off to touch down, it read 57 minutes.
 It all looks to mean a burn to me, but that what I put in the tank, and the ipad time  gives me a 57 minute flight.
 I will do more checks but.
 Any comments
 Alan
 Alan
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Alan Carter
				 Posted: Fri Oct 31, 2014 2:22 pm    Post subject: Re: 57 minuts on 13 ltrs on a 914 |
				Hi All.
 Did another check today, Air bourn times, 1.04 min and 1.32 min
 total 2.36 mins or 2.6 hrs,  took 38 litres to top up, so 14.6 average ltr/hr this dose not include the 30 min taxing around on the ground and doing the power checks.
 Still can,t get the flow meter correct, it asked for 46 litres but I could only get 38 in the tank. So over reading by 8 litres on this occasion.
 Alan
		Alan Carter
				 Posted: Thu Nov 06, 2014 3:11 am    Post subject: Re: 57 minuts on 13 ltrs on a 914 |
				Hi ALL
 Still have not managed to calibrate my flow meter yet,
 But I can say having checked a few times, I get a full hours flying on 14 litres,
 Start up taxy  airborne for one hour  land taxy refill 14 lts.
 I think that's pretty good for a 914
 Alan
		bill.sue(at)orcon.net.nz Guest
				 Posted: Thu Nov 06, 2014 4:47 pm    Post subject: 57 minuts on 13 ltrs on a 914 |
				What boost and RPM are you using to get that Alan?
 Are you Mono or Trigear?
 Rgds
 Sue and Bill Sisley
 On 7/11/2014 12:11 a.m., Alan Carter wrote:
  Hi ALL
  Alan
  http://forums.matronics.com/viewtopic.php?p=432994#432994
		Alan Carter
				 Posted: Fri Nov 07, 2014 1:40 am    Post subject: Re: 57 minuts on 13 ltrs on a 914 |
				Hi Bill.
 I am not sure Bill but it around 28 to 29, about 110/115 kts, Its a really good consumption, for a Tri Gear .Surprised me, must be a good engine 550 hours. Prop PV50.again I think it a good prop, As I have always said ,I it looks right it is right sod all the specifications.
 I have flow 3 times all about 57, 61 minutes air bourn and refilled to the neck of the filler. I can not give you a cruise burn as I have not got the flow meter set up correctly yet. But I do know what I put in the tank to refill it.
 Alan
		tennant
				 Posted: Mon Nov 10, 2014 12:39 am    Post subject: Re: 57 minuts on 13 ltrs on a 914 |
				Alan,
 That sounds about right for the Europa. I don't usually fly so slowly but I checked yesterday and got the following:
 MP 25,5
 3000 ft
 14 L / hr
 115 Kt
 Mono
 The fuel flow takes some time to calibrate, it took me about 3 years to get it spot on.
 Barry
  _________________ Barry Tennant
D-EHBT
At EDLM  -  Germany |
		Alan Carter
				 Posted: Mon Nov 10, 2014 2:28 am    Post subject: Re: 57 minuts on 13 ltrs on a 914 |
				Hi Barry,
 That's pretty good. Mono,s are quit fast.
 My figures are for a Tri Gear, with the speed kit on, and using MTOW
 1370 Lbs so again a good burn
 It will do 120 but 110 to 115 feels right.
 Alan
		Roland
