Dimmers
orchidman
PostPosted: Sun Feb 10, 2008 12:15 pm    Post subject: Dimmers Reply with quote
I can't find that much on this subject via 'Search' so I am asking the experts Laughing
I am at the point of identifying what type of dimmer(s) I am going to go with. Van's has a single channel for $20 and a 4 channel for $115. The catalog lists the 4 channel as a Pulse Width Modulation which sounds good but in the archives here there is one comment about a PWM unit having problems with a 430W. Paul says that they have a dual channel unit for $75 and it sounds like it is a voltage regulation type.
Price wise the Van's single unit is the cheapest available but it doesn't say anything about if it is a PWM or a standard type voltage regulation unit.
My questions are, which method of control is better, voltage regulation or PWM, and how many circuits are people usually going with?
I will have a dual AFS system, 430W, SL40, 327, PM8000B, TT ADI and other rather standard cockpit lights.
Thoughts please.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
pitts_pilot(at)bellsouth.
PostPosted: Sun Feb 10, 2008 3:01 pm    Post subject: Dimmers Reply with quote
I had a nice schematic for a transistor dimmer, but I can't find it.
Here's a more complex but very workable design from Aeroelectric.com.
http://www.aeroelectric.com/articles/Dimmers/9013_Ins.pdf
Linn
orchidman wrote:
I can't find that much on this subject via 'Search' so I am asking the experts [Laughing]
Thoughts please.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=163325#163325
orchidman
PostPosted: Sun Feb 10, 2008 3:58 pm    Post subject: Re: Dimmers Reply with quote
Linn
I have seen this but I was hoping that I would not have to 'role my own'. Plus this one requires a heat sink equaling heat and higher wattage consumption.
My hope is that I could get some discussion about the Pulse Width Modulation types and if there are any negatives.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
PostPosted: Sun Feb 10, 2008 6:11 pm    Post subject: Dimmers Reply with quote
orchidman wrote:
--> RV10-List message posted by: "orchidman" <gary(at)wingscc.com> (gary(at)wingscc.com)
Linn
I think Aeroelectric sells it built. Or maybe they used to.
The power has to go somewhere. The old potentiometer type dimmers were a really high watage variable resistor that also got pretty hot ....
The only negative I can think of is that switching on/off like that might produce ripple (read noise) on the power bus. You can use a 555 timer (Radio Shack) to drive a power transistor (the 555 won't handle a lot of current), but we're back to the heat sink if there's a lot of incandescent lamps. If you go to LED lighting, the power consumption will be less, and lessen the need for a heatsink.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=163369#163369
Tim_Lewis(at)msm.umr.edu
PostPosted: Sun Feb 10, 2008 6:39 pm    Post subject: Dimmers Reply with quote
I'm using the $115 one from Vans. The instructions include a very
modest modification (2 resistors, one capacitor, details at
http://fdatasystems.com/Manuals/LC-40_Garmin.pdf) to use the PWM signal
with the Garmin 400/500 series units. I elected to follow the dimmer
manufacturer's suggestion, however, and just use the built in photocell
in my 530W to dim the unit automatically. I can always tie it in to the
dimmer later if desired.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction
Thoughts please.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
Tim Olson
PostPosted: Sun Feb 10, 2008 6:42 pm    Post subject: Dimmers Reply with quote
Van's, and Stein both sell some dimmers that work well for
most instrument and radio lighting. Especially if you use
LED's, it's not like you're going to be drawing a lot of
power. I'm sure all of my dimmable circuits likely come to
less than 1A by a fair margin.
Make sure you evaluate your panel in full before worrying
too much about dimmers. I have 2 dimmers, small ones, and
they are for instrument lights, and one for the overhead
lights. Most avionics will auto-dim, or have their own
adjustment. So, you're only really looking at things
like the compass, ADI, CDI, and perhaps one or two other
small things that will even have a dimmer hooked up to it.
>> Linn
> Gary Blankenbiller
> RV10 - # 40674
> Fuselage SB
> (N410GB reserved)
orchidman
PostPosted: Sun Feb 10, 2008 7:23 pm    Post subject: Re: Dimmers Reply with quote
Tim, thanks for the link. That lead me also to the main manual. Both have given me the information I need to evaluate this option. Looks good.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
tdawson-townsend(at)auror
PostPosted: Mon Feb 11, 2008 6:22 am    Post subject: Dimmers Reply with quote
I like the dimmers from Perihelion: http://www.periheliondesign.com/egpavr.htm
TDT
Tim Dawson-Townsend
40025 Almost done with Wheelpants!
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
