leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sat Jan 24, 2009 11:37 am Post subject: Pipe for bending leading edge |
Well I've waited long enough, it's time to get on with the wings.
I have a few questions. The drawing calls for a 1 3/8" diameter tube for bending the leading edge. I'm thinking of using the vacuum method, and this will likely be either next weekend, or within a few weeks.
Does PVC pipe have adequate rigidity? Are 12 foot lengths commonly available? If not PVC I'm concerned as to what I'm going to do with a 12 foot length of steel pipe once I'm done. This is a scratch build, so please don't tell me they come pre-bent.
Dan Dempsey
_________________ Scratch building XL with Corvair Engine |
lwinger
Posted: Sat Jan 24, 2009 12:00 pm Post subject: Pipe for bending leading edge |
Dan,
Check out http://www.ch601.org/resources/Nose%20Skin/bending_a_nose_skin.htm. I used this method, with my worktable as bending brake, and it worked great.
Good luck. Follow the directions on their site and you'll have no problems.
Larry Winger
650/Corvair
Scratch building
Fuselage 98% complete
On Sat, Jan 24, 2009 at 11:37 AM, leinad <leinad(at)hughes.net (leinad(at)hughes.net)> wrote:
[quote]--> Zenith-List message posted by: "leinad" <leinad(at)hughes.net (leinad(at)hughes.net)>
Dan Dempsey
http://forums.matronics.com/viewtopic.php?p=226560#226560
ties such as List Un/Subscription,
://www.matronics.com/Navigator?Zenith-List" target="_blank">http://www.matronics.com/Navigator?Zenith-List
ref="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
p; -Matt Dralle, List Admin.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
leinad
Posted: Sat Jan 24, 2009 7:11 pm Post subject: Re: Pipe for bending leading edge |
Wade,
That's the method I was going to use, but what type of pipe did you use? Is it PVC? Do you think PVC would work?
Dan
wjones(at)brazoriainet.co wrote: | Hey Dan ,I had good results using this method. Wade Jones � � � � �
Note: or receiving certain types of file attachments. Check your e-mail security |
Description: |
Filesize: |
56.67 KB |
Viewed: |
499 Time(s) |
Afterfxllc(at)aol.com Guest
Posted: Sat Jan 24, 2009 8:46 pm Post subject: Pipe for bending leading edge |
You have to use gas pipe or galvanized pipe PVC would flex
Jeff
A Good Credit Score is 7001028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Sat Jan 24, 2009 9:05 pm Post subject: Re: Pipe for bending leading edge |
Dan, Ditto on what Larry said. I did the bending solo on top of my table. That's one of the things I like about this design, one guy can do most of the work.
If you are going the vacuum route I would imagine rigidity and straightness of the tube will be important. Also you will need to keep the tube aligned to the skin during the process.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
William Dominguez
Posted: Sun Jan 25, 2009 6:33 am Post subject: Pipe for bending leading edge |
I remember seeing a video in youtube with some guys bending the nose skin for a Sonex. If I remember correctly, they used a PVC tube. I don't find the video right now but if I find it, I'll post the link.
I have considered the table method described in CH601.org but my table is very heavy and have lot of things stored in it, my floor is not perfectly flat and my workshop does not provide enough clearance to easily turn the table upside down. I'll be using the vacuum method as well.
William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom
--- On Sat, 1/24/09, leinad <leinad(at)hughes.net> wrote:
Quote: | From: leinad <leinad(at)hughes.net>
Subject: Re: Pipe for bending leading edge
Date: Saturday, January 24, 2009, 10:11 PM
Quote: | --> Zenith-List message posted by: "leinad"<leinad(at)hughes.net>Wade,That's the method I was going to use, but what type of pipe did you use? Is it PVC? Do you think PVC would work?Danwjones(at)brazoriainet.co wrote:> Hey Dan ,I had good results using this method. Wade Jones � � � � � > > Note: or receiving certain types of file attachments. Check your e-mailsecurity--------Scratch building XL with Corvair EngineRead this topic online here:http://forums.matronics.com/viewtopic.php?p=226625#226625Attachments:
http://forums.matronics.com//files/100_2528_2_174.jpg< -->
| [quote][b]
_________________ William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom |
leinad
Posted: Sun Jan 25, 2009 8:18 am Post subject: Re: Pipe for bending leading edge |
William,
I've seen the video. It has been awhile, but I remember it differently. I thought they were using a steel pipe.
Ron is great proponent of the table top bending jig method, and I'm sure it can work and do a good job. I'm looking at using the vacuum method for a couple of reason, maybe not good ones, but here they are. I used the table top method with the stabelizer leading edge and the results weren't so good. There is slight, and if I pointed it out to you you'd notice it, curve to the leading edge. It results in the middle being higher than the tips. It's installed on the plane now, but I think I'm going to remake that part. Also I made my table in 2 sections, one 8 foot long the other 4 foot long. Third, it seams like you'd have better control with the vacuum, you could apply it slowly and not feel like you're wrestling with it.
Here's my thinking on not needing a rigid tube. It should be similar to folding a sheet of paper which can result in a perfectly straight line with out any guide at all. I think all one should have to do is draw a straight line on the material. Place the tube on that line, and hold it in place with a few pieces of duct tape. The force of the vacuum is going to be very constant along the entire length of the bend. This is complete conjectures on my part. Jeff has already spoken up and said the tube must be rigid. Jeff was this from experience from vacuum forming using PVC, or your best guess?
Short of any replies based on real experience I may purchase some aluminum flashing and try a scaled down test, perhaps using something really flimsy as radius guide.
Dan
[quote="William Dominguez"]I remember seeing a video in youtube with some guys bending the nose skin for a Sonex. If I remember correctly, they used a PVC tube. I don't find the video right now but if I find it, I'll post the link.
William Dominguez
Zodiac 601XL Plans
Miami Florida
Quote: | --> Zenith-List message posted by: "leinad"<leinad>Wade,That's the method I was going to use, but what type of pipe did you use? Is it PVC? Do you think PVC would work?Danwjones(at)brazoriainet.co wrote:> Hey Dan ,I had good results using this method. Wade Jones � � � � � > > Note: or receiving certain types of file attachments. Check your e-mailsecurity--------Scratch building XL with Corvair EngineRead this topic online here:http://forums.matronics.com/viewtopic.php?p=226625#226625Attachments:
bjohnson(at)satx.rr.com Guest
Posted: Sun Jan 25, 2009 9:05 am Post subject: Pipe for bending leading edge |
I bent my Sonex leading edge skin using the Vacuum method with a PVC
pipe, worked just fine. There is no bending force on the pipe.
Bruce Johonson
Plans Building a Sonex in Schertz TX
On Gear.
leinad wrote:
Quote: |
William,
Dan
William Dominguez
Zodiac 601XL Plans
Miami Florida
hills(at)sunflower.com Guest
Posted: Sun Jan 25, 2009 10:41 am Post subject: Pipe for bending leading edge |
Ya, I did my Sonerai wing skins with the vacuum method, it works like magic.
But, be sure to have something limiting the bend radius, it works to fast to
do it by hand (I used a 2" pvc pipe)
Roger
leinad
Posted: Sun Feb 01, 2009 7:23 pm Post subject: Re: Pipe for bending leading edge |
I got one nose skin bent today. Using the vacuum method it went well. I ran out of time (had to go to a Super Bowl party) before I finished the second one. I used steel pipe, which I had to join because the longest lengths I could find were 10 feet.
THere are pictures on my web site at:
http://daniel.dempseyfamily.us/zodiac/index.html
Jeyoung65(at)aol.com Guest
Posted: Sun Feb 01, 2009 7:49 pm Post subject: Pipe for bending leading edge |
Just a question, I have always been told to check cable tension in the middle of the cable run and not at the ends. It has beena very long time since I have checked any cables so not sure this is true. Have you compared the cable tension at the end and in the middle of the run? Jerry of GA DO NOT ARCHIVE
In a message dated 2/1/2009 10:27:14 P.M. Eastern Standard Time, leinad(at)hughes.net writes:
Quote: | http://daniel.dempseyfamily.us/zodiac/index.html |
From Wall Street to Main Street and everywhere in between, stay up-to-date with the [url=http://aol.com?ncid=emlcntaolcom00000023 ]latest news[/url].
Ron Lendon
Posted: Sun Feb 01, 2009 8:48 pm Post subject: Re: Pipe for bending leading edge |
Looking good Dan, hope your team won. Did ya get any pictures with the vacuum applied and the part totally collapsed?
CH 601 XLB
N601LT - Flying
kmccune
Posted: Mon Feb 02, 2009 4:58 am Post subject: Re: Pipe for bending leading edge |
I t does not look as though you drilled holes in the pipe? I drilled holes along one side down the pipes length for the stab and elevator skins. I assume that you let the vac suck out one end inside the plastic? This is interesting, because I don't want to ruin another pipe by drilling holes in it when I do my wing skin!
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
leinad
Posted: Mon Feb 02, 2009 9:47 am Post subject: Re: Pipe for bending leading edge |
Ron,
No I didn't. I picked up the camera to shoot one, but just about the time I was ready to take the picture a hole developed in the plastic and let the air out. The part was already bent, so I saw no use in fixing the hole just for a picture. I'll try again next time, maybe ask for an assistant on that issue.
Dan
Ron Lendon wrote: | Looking good Dan, hope your team won. Did ya get any pictures with the vacuum applied and the part totally collapsed? |
leinad
Posted: Mon Feb 02, 2009 9:59 am Post subject: Re: Pipe for bending leading edge |
Kevin,
I may drill holes for the next one. The pipe has already been claimed for a couple of closet rods, so a few holes won't matter. I had a very thin wall piece of brass pipe from a sink drain in a pile of junk and I took that and crushed one end in the vice. This became my "nozzle" which I fastened to the end of the vacuum cleaner hose. It worked OK but was hard to tape in place.
One thing I'm not certain about is whether I'll regret not drilling the rivet holes before bending. Has anyone done it that way? I'm going to have to lay all my holes out on a now curved surface.
Dan
kmccune wrote: | I t does not look as though you drilled holes in the pipe? I drilled holes along one side down the pipes length for the stab and elevator skins. I assume that you let the vac suck out one end inside the plastic? This is interesting, because I don't want to ruin another pipe by drilling holes in it when I do my wing skin!
Kevin |
carlossa52(at)gmail.com Guest
Posted: Mon Feb 02, 2009 10:18 am Post subject: Pipe for bending leading edge |
Dan, you mean "two flat surfaces with a narrow curved surface in between"...
Carlos
2009/2/2 leinad <leinad(at)hughes.net (leinad(at)hughes.net)>
Dan[b]
naumuk(at)windstream.net Guest
Posted: Mon Feb 02, 2009 3:28 pm Post subject: Pipe for bending leading edge |
Dan-
No, you can lay out your holes on a flat surface. Use a piece of scrap
sheet and drill your holes in it, then duct tape the stock to your nose skin
and transfer using a Sharpie. I believe Larry Mac's site has pictures. For
an XL, compared to the tapered wing of an HDS, this should be a snap.
