brubakermal(at)yahoo.com Guest
Posted: Mon Jan 23, 2012 9:16 am Post subject: pusher belt drive prop |
Is a prop for a pusher belt drive the same as a prop 4 a tractor W/a gear box ?
my budy needa a prop for a 503 belt drive 60in to put on his quicksilver float plane
Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022
Sent: Monday, January 23, 2012 8:38 AM
Subject: Re: Key West Regulator
--> Kolb-List message posted by: "George Alexander" <gtalexander(at)att.net (gtalexander(at)att.net)>
Ed:
I’m not an expert, but I believe that it should be to the airframe. Every drawing that I have seen shows a common ground (airframe?) throughout the installation.
A couple of “However�s though….
Many installations put a separate grounding strap from the engine to the airframe (a braided strap) and then ground, at a convienant place, the devices fed by the system.
If the loads off the KW are not too demanding and depending on how they are wired, the brown to the Neg (-) on the KW would be “ok�, not ideal, but “ok�.
As Beauford would say.... "Worth what you paid for it!" (Who by the way, uses a KW and an EIS.)
DAquaNut(at)aol.com wrote:
| Quote: | George, � I was the one who wired my firefly originally and have 170 hours on it. Do I need to run
� the brown wire from the engine to the airframe? That is the only one in question. It seems
� Crazy at this point, but I may not have had it right ,all along.
� Ed Diebel (FF 62)
In a message dated 1/22/2012 4:13:46 P.M. Central Standard Time, gtalexander(at)att.net (gtalexander(at)att.net) writes:
> Ed:
> The brown should go to ground. The yellow and the yellow/black should go to the input (A/C) to the Key West. The output (DC) of the Key West would tie into whatever you have that requires the 12V DC. The brown (ground) going to the negative side of the output of the KW may have been someone's way of getting the engine ground to whatever is being fed by the KW.
> For further confusion go to Google and put in "Rotax Wiring Diagram". It'll make your hair hurt.
> Your results may vary.
George Alexander
FS II R503 N709FS
http://www.oh2fly.net
http://forums.matronics.com/viewtopic.php?p=364558#364558http://www.matronics.com/Navigator?Kolb-List
pj.ladd(at)btinternet.com Guest
Posted: Mon Jan 23, 2012 9:39 am Post subject: pusher belt drive prop |
prop for a 503 belt >>
Hi,Malcolm
I used belts from the local car spares dealers on my Challenger.
Might be worth changing them a bit sooner than the `approved` aero suppliers belts.They looked just the same to me but they were cheap enough.
Pat
byoungplumbing(at)gmail.c Guest
Posted: Mon Jan 23, 2012 9:40 am Post subject: pusher belt drive prop |
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>
stand behind both planes with the engine mounted,,, and see what direction the props turns,, if both turn clockwise,,, or both turn counter clockwise,,, as far as i know they could use the same prop.... if they turn opposite directions,,, i think you are out of luck.
Posted: Mon Jan 23, 2012 2:35 pm Post subject: pusher belt drive prop |
if they turn opposite directions,,, i think you are out of luck.>>
Can someone explain what possible difference that makes. The `teeth` seem to be exactly the same, not with any particular bias. I cannot remember the belt having a direction arrow on it
Pat
Posted: Mon Jan 23, 2012 2:51 pm Post subject: pusher belt drive prop |
Patrick L/Kolbers:
Let's see if I can help.
I think the gentleman was talking about props, not belts.
Pat
[quote] [b]
_________________ John Hauck
Titus, Alabama |
Posted: Mon Jan 23, 2012 3:59 pm Post subject: pusher belt drive prop |
Pat
I thought the question was can they use the same prop on a geared pusher and
a belted tractor,,,, if standing at the rear of the plane and they both
turn clockwise,,, the the same prop could be used,,,, if they turn
opposite directions the props need to have the opposite twist,\\
boyd young
Posted: Mon Jan 23, 2012 4:25 pm Post subject: pusher belt drive prop |
now i need to buy one maybe the challanger guys or flitestar phantom group or maybe a ultrastar pilot anybody mal
To: Pat Ladd <pj.ladd(at)btinternet.com>; kolb-list(at)matronics.com
Sent: Monday, January 23, 2012 6:53 PM
Subject: Re: pusher belt drive prop
--> Kolb-List message posted by: "b young" <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)>
Pat
I thought the question was can they use the same prop on a geared pusher and a belted tractor,,,, if standing at the rear of the plane and they both turn clockwise,,, the the same prop could be used,,,, if they turn opposite directions the ->
Posted: Tue Jan 24, 2012 8:18 am Post subject: pusher belt drive prop |
a belted tractor,,,, >>
If that was I totally missed it. Sorry
Pat
