		brubakermal(at)yahoo.com Guest
				 Posted: Mon Jan 23, 2012 9:16 am    Post subject: pusher belt drive  prop |
				Is a prop for a pusher belt drive the same as a prop 4 a tractor W/a gear box ?
  my budy needa a prop for a 503 belt  drive 60in to put on his quicksilver float plane
 Malcolm & Jeanne Brubaker  Michigan Sport Pilot Repair  LSRM-A, PPC, WS Great Sails - Sailmaker  for Ultralight & Light Sport (989)513-3022
  Sent: Monday, January 23, 2012 8:38 AM
  Subject: Re: Key West Regulator
  --> Kolb-List message posted by: "George Alexander" <gtalexander(at)att.net (gtalexander(at)att.net)>
 Ed:
 I’m not an expert, but I believe that it should be to the airframe.  Every drawing that I have seen shows a common ground (airframe?) throughout the installation.
 A couple of “However”s though….
 Many installations put a separate grounding strap from the engine to the airframe (a braided strap) and then ground, at a convienant place,  the devices fed by the system.
 If the loads off the KW are not too demanding and depending on how they are wired, the brown to the Neg (-) on the KW would be “ok”, not ideal, but “ok”.
 As Beauford would say.... "Worth what you paid for it!"  (Who by the way, uses a KW and an EIS.)
 DAquaNut(at)aol.com wrote:
  	  | Quote: | 	 		   George,         �   I was the one who wired my firefly originally and have 170 hours on  it.   Do I need to   run
              �             the brown wire from the engine to the airframe?  That is the only one in  question. It seems
             �            Crazy at this point, but I may not have had it right ,all along.
              �              Ed   Diebel       (FF 62)
    In a message dated 1/22/2012 4:13:46 P.M. Central Standard Time,  gtalexander(at)att.net (gtalexander(at)att.net) writes:
  >  Ed:
  > The brown should go to ground.  The yellow and the   yellow/black should go to the input (A/C) to the Key West. The output    (DC) of the Key West would tie into whatever you have that requires the 12V    DC.  The brown (ground) going to the negative side of the output of the    KW may have been someone's way of getting the engine ground to whatever is    being fed by the KW.
  > For further confusion go to Google and put in    "Rotax Wiring Diagram".  It'll make your hair hurt.
  > Your results    may vary.
 George Alexander
 FS II R503  N709FS
 http://www.oh2fly.net
 Read this topic online  here:
 http://forums.matronics.com/viewtopic.php?p=364558#364558http://www.matronics.com/Navigator?Kolb-List
				 Posted: Mon Jan 23, 2012 9:39 am    Post subject: pusher belt drive  prop |
				prop for a 503 belt  >>
  Hi,Malcolm
  I  used belts from the local car spares  dealers on my Challenger.
  Might be worth changing them a bit sooner than the  `approved` aero suppliers belts.They looked just the same to me but they were  cheap enough.
  Pat
		byoungplumbing(at)gmail.c Guest
				 Posted: Mon Jan 23, 2012 9:40 am    Post subject: pusher belt drive  prop |
  	  | Quote: | 	 		  >>>>>>>>>>>>>>>>>>>>>>>>
  stand behind both planes with the engine  mounted,,,  and see what direction the props turns,,  if both turn  clockwise,,, or both turn counter clockwise,,,  as far as i know they  could use the same prop....    if they turn opposite  directions,,,  i think you are out of  luck.
				 Posted: Mon Jan 23, 2012 2:35 pm    Post subject: pusher belt drive  prop |
				if they turn opposite directions,,,  i  think you are out of luck.>>
  Can someone explain what possible difference that  makes. The `teeth` seem to be exactly the same, not with any particular bias. I  cannot remember the belt having a direction arrow on it
  Pat
				 Posted: Mon Jan 23, 2012 2:51 pm    Post subject: pusher belt drive  prop |
				Patrick L/Kolbers:
 Let's see if I can help.
 I think the gentleman was talking about props, not belts.
 Pat
 [quote]  [b]
  _________________ John Hauck
Titus, Alabama |
				 Posted: Mon Jan 23, 2012 3:59 pm    Post subject: pusher belt drive  prop |
 Pat
 I thought the question was can they use the same prop on a geared pusher and
 a belted tractor,,,,     if standing at the rear of the plane and they both
 turn clockwise,,,  the the same prop could be used,,,,   if they turn
 opposite directions the props need to have the opposite twist,\\
 boyd young
				 Posted: Mon Jan 23, 2012 4:25 pm    Post subject: pusher belt drive  prop |
				now i need to buy one   maybe the challanger guys or flitestar phantom group or maybe a ultrastar pilot  anybody mal
  To: Pat Ladd <pj.ladd(at)btinternet.com>; kolb-list(at)matronics.com
  Sent: Monday, January 23, 2012 6:53 PM
  Subject: Re: pusher belt drive  prop
  --> Kolb-List message posted by: "b young" <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)>
 Pat
 I thought the question was can they use the same prop on a geared pusher and a belted tractor,,,,     if standing at the rear of the plane and they both turn clockwise,,,  the the same prop could be used,,,,   if they turn opposite directions the ->
				 Posted: Tue Jan 24, 2012 8:18 am    Post subject: pusher belt drive  prop |
 a belted tractor,,,,  >>
 If that was I totally missed it. Sorry
 Pat
